  #1
Old 12-08-2007, 05:55 PM
duramaxin14's Avatar
duramaxin14 duramaxin14 is offline
Just Keeping Up
Default Free lly mods
What kinda free mods can i do to my truck say to help out with fuel and air. I dont understand the pvc stuff can someone break that down in kindergarden terms for me. Cp3 mod is in the works am i missing anything??
__________________
2016 crew cab f150 4x4 5.0
  #2
Old 12-08-2007, 06:13 PM
speedy03's Avatar
speedy03 speedy03 is offline
Gearhead
Default
What i did for the PCV Re-Route is use a 3/4 by 1/2" 90* copper fitting and 6' of 3/4" heater hose. I ran the hose by the frame rail and cut it off at an angle by the ABS in-between the doors.
__________________
-Kade-
05 silverado LLY Duramax/allison, CC SB, 4x4, LT: EGR blocked, PCV Re-Routed, MBRP 4" turbo back exhaust, EFI live, DSP5, PPE ported fuel fitting
03 silverado RC,SB 5.3L
mid 11's Now for sale.
  #3
Old 12-08-2007, 06:37 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Kade ,that looks good
mine was setup just like yours,but it would constantly drip a lil bit of oil...no matter how tight the hose clamp was
Kurt, there is some minor mods if you search through the dmax tech section
not many things in life are free and as for the PCV rerought i recomend this to anyone,next D-Max i buy it will be done as soon as i get off the lot
but its not for POWER its for cleanliness
do you have a blocker plate?
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #4
Old 12-08-2007, 06:43 PM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
You can also get rid of your egr cooler and motor if you have a buddy that can weld, just remove all the egr mess, and where the egr motor connects to the intake, just weld covers over the holes. Install a 1/8" plate over where you have installed the egr blocker plate and put in a section of heater hose where the egr cooler was.......shouldnt cost you but $20.00 in parts for this one. you got a homemade egr delete kit.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #5
Old 12-08-2007, 06:46 PM
Default
You can also open up your turbo inlet pipe as described in this thread and plug the pcv and resonator inlets
http://www.mcratracing.com/forum/showthread.php?t=2003
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #6
Old 12-08-2007, 06:49 PM
Just Keeping Up
Default
Kade since u only live about 20 mins from me i liked to catch up some time. Maybe pay u some money if u fill like doing another dirty if not i will be able to better understand it by talking to u and seeing it up close.
__________________
  #7
Old 12-08-2007, 06:52 PM
Just Keeping Up
Default
Larry i already done the fuel rail fitting. I will look more into the re route and the egr delete. Simon the egr is blocked its got the ppe blocker plate. Now all i got to do is the cp3 mod and a cheetah charger.
__________________
  #8
Old 12-08-2007, 07:22 PM
Mike Mike is offline
hmmm....
Default
Is it free if someone else pays for it for you?
__________________
2004 lb7 2500 cclb 4x4 <- Wrecked / repairing for daughters ride.
2005 LLY 3500 cc 4x4 <- Gone
2007 lmm excb 4x4 dually GMC <- Gone
2015 LML cclb 4x4 dually GMC Tow hog
2015 LML ccsb 4x4 GMC Denali ( wife's ride ) Needs a " this is not my husbands ride " sticker.
  #9
Old 05-06-2008, 06:37 AM
Default
moved here
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #10
Old 05-06-2008, 11:18 AM
psyco66's Avatar
psyco66 psyco66 is offline
Default
Just wondering what is the CP3 mod?
__________________
JOHN
05 4 door short bed 4x4 chevy LLY
EFI LIVE with McRat tune, DSP5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Tinted tail lights, Suncoast stage 4 built by me.
NO TALKING JUST LINE IT UP
  #11
Old 05-06-2008, 12:23 PM
radvans radvans is offline
Default
What model year trucks is the pcv mod good for? Only 4.5 and above?
  #12
Old 05-06-2008, 12:28 PM
malibu795's Avatar
malibu795 malibu795 is offline
Default
Quote:
the lly and new routes the PCV (positive crankcase ventialation) back into the intake.. good for emission
bad thing is it can lead to a runaway condition on a diesel and the is VERY bad
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #13
Old 05-06-2008, 12:37 PM
Default
Not sure i'm following you Adam, are you saying the way the factory has it will create a runaway condition or when we re-route it the runaway condition can happen
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #14
Old 05-06-2008, 12:50 PM
malibu795's Avatar
Default
Quote:
say your crankcase floods with fuel. only opening is either gasket or the PCV.
if the PCV is routed like a gasser back into the intake were is the fuel going to go? back into the intake and the engine will burn it.
BTW when mine flooded i got fuel oil and coolant all under the truck..
__________________
Adam
  #15
Old 05-06-2008, 12:56 PM
ROGUE GTS ROGUE GTS is offline
Default
PCV in a diesel is bad because it pumps oil into the intake, which is what can cause the runaway condition, aka you're pumping oil that will burn as fuel into the motor in an uncontrolled fashion.
Ditch the pcv and the issue goes away, as does coating your turbo, pipes, and IC with a layer of oil.
__________________
04.5 LLY CC/SB 4x4 DA.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
