  #1
Old 10-25-2009, 07:21 PM
tpijeep tpijeep is offline
FNG
Default Engine Starts and instantly dies
I have been battling this for a while and search has yielded no results. On occasion I will start my truck and it will fire and die in under a second, then you have to crank it about 3 times longer then normal for it to run normally. It generally does this when hot but not always.. I just put a new set of injectors in it because i had all the symptoms of injector failure, it now runs perfectly but today it pulled its no start trick.
After 2 days of wrenching it was dishearting to have it die again...
  #2
Old 10-25-2009, 08:10 PM
messejme's Avatar
messejme messejme is offline
Jazzy, Me and Max
Default
the plastic bleed screw on the fuel filter housing may me leaking air into the fuel system
__________________
04.5 LLY dooley CC. EFILive, SC IV, 1058, race valve, Airdog-150, 4" stack, Socal built engine, S480 over GT4094vvt stage 2, 60% overs, arson III CP3, flo pro extreme headers and up-pipes, PPE dual CP3's
  #3
Old 10-25-2009, 08:32 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Could be the filter isnt quite sealed, too. May also be a very small air leak in one of the rubber fuel lines.
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
2014 Chevy Cruze Diesel -- the DD
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
From mufflerguy on yb,
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!"
  #4
Old 10-26-2009, 06:41 AM
FNG
Default
Okay, I am doing a H2O/Meth kit today, I will check the hoses, filter is new, didn't know if a leak on the low psi side could cause this. Thanks..
  #5
Old 10-26-2009, 06:58 AM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
Does it set any codes? Sometimes the ignition fuses under the hood loosen up and doesn't make good connections causing similar problems.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #6
Old 10-26-2009, 06:57 PM
FNG
Default
No codes, checked the filter, checked the lines on the filter, went to real hose clamps rather than the factory clamps, still had the no start once after.. Dealer claims they have never had that issue, this was after they denied my injector claim at 117k
  #7
Old 10-27-2009, 07:27 PM
StrobeLite's Avatar
StrobeLite StrobeLite is offline
FNG
Default
Check your cam sensor. Sounds exactly like a problem I had.
__________________
(Mike)
2001 ECSB ZF puller
B.T.P.A. member
  #8
Old 10-27-2009, 07:29 PM
Max Power Max Power is offline
Gearhead
Default
Are you sure it's not a passlock security issue?
IF you have EFI Live, try disabling VATS and see if that fixes it.
  #9
Old 10-27-2009, 07:46 PM
S Phinney's Avatar
Default
Thats what I was talking about with the fuse issue. When it loosens up the ecm thinks someones trying to steal it and shuts it off. If it's that fuse disabling the VATS will not change anything though. To check it out it will be harder to find. See if your door chime changes sound while wiggling the ign. fuses under the hood.
__________________
  #10
Old 10-28-2009, 07:12 AM
FNG
Default
Double whammy here, no EFILive and the factory door chime was removed when I got rid of the factory radio.. I have never seen the Vats light flash when it did this so I am not sure... any other ideas with the cam sensor?
  #11
Old 06-03-2010, 09:35 AM
ncalmax ncalmax is offline
FNG
Default
I hate to bring back an old thread but I have the same thing going on.
2004.5 duramax
Here is a quick run down of mine situation. It started doing this last summer when temps were over a 100*. If I shut the truck off when it's over 100* it will do it every time. Run for 15-20 secs then shut down(loses fuel preasure). It also does this if I shut it off if it's below 35*.
So now that it is starting to warm up it now does it when I shut it off at 85* and hotter. If the temps are between 35*-85* it will start fine every time no issues.
I have replaced two fuel filters I took it to the dealership they checked the housing and all around that area for leaks and found nothing.
Hope someone can help it's getting very old having to prime it back up.
  #12
Old 06-03-2010, 09:49 AM
dmaxfireman's Avatar
dmaxfireman dmaxfireman is offline
'Can do' kind of guy
Default
if priming it starts the truck you are either drawing air or bleeding off pressure.
is your truck stock?
__________________
-Fireman
  #13
Old 06-04-2010, 08:10 AM
FNG
Default
No not stock just a bullydog programmer and straight exhaust.
  #14
Old 06-15-2010, 03:37 PM
duramaxGMC duramaxGMC is offline
FNG
Default
My truck is doing the exact same thing. The temperature over 85 is the same also. I prime the air out and it starts up after a few seconds every time. It is getting air in the fuel line from some where. I am going to replace my bleeder screw first. ???
  #15
Old 06-15-2010, 04:49 PM
wes06dmax's Avatar
wes06dmax wes06dmax is offline
Default
There is a line next your prime pump that looks like a spark plug line make sure it is all the way down I have a friend that had the same problem and we tryed everything i was getting agravated and just touched it and it made a clicking sound and it has run fine ever since
__________________
06 LBZ
Sting Built Sled Puller,Race Truck, Daily Driver
EFI Live
FASS 95
2.6 Turbo
Fleece 60% Over Injectors
SunCoast Stage 4, 1056,
Carrillo Rods
Yukon Gears, Axles, Grizzley Locker, Eaton E-Locker
PPE Tie Rod Sleeves
Cognito Braces
Hamilton Cam Valve Springs
Mahle Pistons
PPE Duel CP3
Big Thanks To Jeff Dean (stingpuller)
and Henry Webb (ripmf666) www.creaturesofthenightperformance.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
