#1
Got my AirDog II pump in this week, I'm going to install today. Any special tips or pointers?
I know I need the fuel line disconnect tools to get the lines apart. Anything else special? Also, is this a flow thru design pump? Say if the pump fails will the truck still run?
__________________
Jeff 2011 Chevy 2500HD LML 4x4 LTZ-Black -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ's 35/12.50's. 2012 VW Jetta TDI - Daily Driver. SOLD - 06 LBZ |
#2
I found it alot easier to pull the bed off.. Are u doing the 1/2 pick up?
__________________
08 CC/SB 2WD -sold 12.89 at 106mph 1.82 60ft.. Tuned by JOSH H [B] |
#3
ADII doesn't require the Pickup.
Pump is flow through, so no worries about that. Nothing much to add on install, pretty straight forward. Good luck.
__________________
2006 CC/SB 4x4 LBZ In the works - Carillo Rods | SoCal Pistons | Dual Cp3's | Twins | SoCal Damper | Keyed Cam & Crank | 100 over Injectors | ??? Team Borrowed Time #15
#4
Ok I didn't know that chad.. The one I bought from u had the pickup
__________________
#5
whats the differance between the ad and adII? when did they change?
eta, i did mine with the bed on, although i had a filter assm already on and when i did it i lowered the tank. so based on that you need the room to do it right. either the bed or the tank. while your in there do the kennedy mod to the sender by switching the feed line to the vent hose side more flow.
__________________
2004 CHEVY CREW CAB ![]()
#6
My AD came with a pickup, but I didn't put it in yet. My fuel pressure gauge is still reading 11psi at idle and drops to about 8 at WOT.
__________________
Shane Gone but not forgotten 06 GMC RCLB 3/4 ton 4x4 Duramax ZF6 Now pimpin a '08 Dodge 3500 Mega Cab. |
#7
The way I understand it, you don't have to drop the tank or remove the bed, hence why I spent the extra money for the 2nd Generation. Hopefully there will be plenty of room.
__________________
#8
Quote:
The AD II is a new design, that is demand flow; Meaning that it only pumps as much fuel as the CP3 needs, which means less fuel/air being returned to the tank. This is why you can use the stock sending unit. It also has an adjustable pressure regulator, so you can choose what psi you want the pump to pressurize to.
__________________
#9
get ready to fight with the 1/2" line, took me a good 30 minutes to get that line apart because its fairly tight spot (depending on what route you go, there is two ways to install it) but after that its very easy. also check to make sure they sent you the right 3/8" female by 1/2" push-lock fitting, i got a 1/4" female instead of the 3/8" and had to wait 2 weeks for a new fitting to be sent to me but im up in Canada
__________________
01 EC/SB Silverado ARB Bumper /w Lightforce 240 HID's • 55W highs/lows • Suncoast IV w/ 1058 by MPL Motorsports • 6" Pro Comp /w Bilstein 5100's • PPE Hot +2 E.T. on lvl 7 • Airdog 2 165 • Banks Ram Air • 4" Magnaflow • Black DC-1's with 315/75R16 Toyo AT's 347k KM and Still Rolling Coal Wish List
HTT Turbo |
#10
Quote:
![]() My friend has a better idea of me just cutting into the metal lines and hooking it up that way.
__________________
#11
It's installed, it's pretty quite.
I like it so far, I don't know if I can feel a difference though? Is the pressure preset on this, or do I have to turn it up?
__________________
#12
should be preset at 10 psi
__________________
HTT Turbo |
#13
i am going to do mine on my LBZ CREW CAB is there a way to bypass the stock filter or am i needing to go through 3 filters cause i know on cummins the run there owne line to the cp3 ??? any help would be awsome !!!!!
Thanks Casey Crider 918-314-4712 |
#14
Quote:
just run a new line from the pump to the inlet on the cp3,or just remove the filter housing,and hook them to lines to each other its as easy as that
__________________
04.5 LBZ/LLY dirttymaxx puller efi live 570 hp 6/11/11 STOCK charger! down pipe,headers,up pipes,egr removed,locker front and rear,ats tranny,7" bull hauler stacks,custom 3" intercooler tubes,3" intake bridge,lots of polished parts |
#15
thanks i just a broke farmer that needs to save 50 bucks on a service...
o fyi i built this trk it was a role over |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
