  #1
Old 09-09-2009, 05:16 PM
ronsway ronsway is offline
FNG
Default P0540 code.
2002, 2500HD, 4X4, auto - I am getting a P0540 code. I have heard that it is the IAH relay. What can I do to further determine the problem? Is this something a "bolt-on" mechanic is try to fix?
  #2
Old 09-09-2009, 05:19 PM
Mike Mike is offline
hmmm....
Default
That could be anything from a bad fuse to a bad heater coil. Time for a volt/ohm meter.
__________________
2004 lb7 2500 cclb 4x4 <- Wrecked / repairing for daughters ride.
2005 LLY 3500 cc 4x4 <- Gone
2007 lmm excb 4x4 dually GMC <- Gone
2015 LML cclb 4x4 dually GMC Tow hog
2015 LML ccsb 4x4 GMC Denali ( wife's ride ) Needs a " this is not my husbands ride " sticker.
  #3
Old 09-09-2009, 05:41 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
That is what the code is for
If the temp of the truck is under 121f and or intake air temp is below73f it will kick on the heater coil
Check the voltage on the heater coil and that will tell us where to start,there is also a wire on the glowplug controller that need to be checked that will elimnate the wire to the plug being the issue
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #4
Old 09-09-2009, 05:43 PM
That's better
Default
Check Ing 1 fuse in the under hood fuse block
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #5
Old 09-09-2009, 05:44 PM
That's better
Default
Quote:
Also can mean a bad ECM
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #6
Old 09-09-2009, 05:52 PM
hmmm....
Default
I didn't know that. Thanks
__________________
  #7
Old 09-09-2009, 05:57 PM
That's better
Default
probably rare Mike,but it happend to a friend of mine
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #8
Old 09-09-2009, 07:58 PM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
I took mine off. Truck runs better. No CEL but there is a constant memory code.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #9
Old 10-07-2009, 04:06 PM
bigblackbronco bigblackbronco is offline
FNG
Default code p0540
OK, the most common thing that sets code p0540 is the air intake relay.
the thing most people don't realize is you don't have to replace this whole box
just take the top off, and what do we have
as you can see it is actually just two separate 70A SPST relays that can be had for $5 almost anywhere on the internet
I hope this helps, if you want to test the relay's there are plenty of how-to's on the internet, but I would just replace them both.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
