  #1
Old 07-28-2009, 12:39 AM
mick mick is offline
Try anything
Default Anybody Identify this Engine Noise?
This is my new built engine that has 1200 miles on it. It started making a noise about the time we found we had a dud injector and its gradually getting worse. Any ideas? RH Side near No 5-7 seems the worst. We had a dud injector at No 7
http://s235.photobucket.com/albums/e...DSCF0002-1.flv
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #2
Old 07-28-2009, 12:52 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
I cant say for sure but new injectors do make noise?even stockers
Think it could be that? Have you done a compression check ( always good for a base compraison
Im sure Mike has the rail at idle diald in? Hmm what else could it be?
balance rates are good? Smoke levels?
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #3
Old 07-28-2009, 12:59 AM
Try anything
Default
Doesnt seem as bad in the vid simon but when your sitting at the lights its embarrasing sometimes - a real knocking - balance rates are excellent
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #4
Old 07-28-2009, 01:01 AM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
shit mick my truck does the same thing...
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #5
Old 07-28-2009, 05:12 AM
JOHNBOY's Avatar
JOHNBOY JOHNBOY is offline
< Rocking the Big Single!
Default
If you take the boost tube of at the intake does it get noiser? You might just need to adjust valves.
__________________
The Big Stick
2002 GMC 2500HD Crewcab Long Bed LB7 ZF6 Southbend Triple Disk clutch, Alive with EFI Live from Mcrat Racing, Crower rods, LB7 cut pistons by JB, Cam and push rods by EEP 80% Extrudehone injectors, CP3 X 2, Socal Diesel Springs and Ti Retainers, A/C delete by JB
The wifes truck
2007 Classic Chevy Crewcab Shortbed LBZ 6speed Allison Loaded Basicly stock. Little EFI tune and a Trans Go Jr.
  #6
Old 07-28-2009, 04:07 PM
Try anything
Default
Quote:
Your saying it may be NORMAL? By the way this engine is 15:1 CR
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #7
Old 07-28-2009, 04:10 PM
Try anything
Default
Quote:
As in how John? You talking about as in Tappet clearance? Or Springs?
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #8
Old 07-28-2009, 04:41 PM
JOHNBOY's Avatar
Default
When mine got noisy it was because of the Rocker Arm to bridge clearence on the exhuast valves was to high on one cylinder. With the intake boost tube off you could hear it poping back for lack of better description. Adjusted lash noise gone.
__________________
The Big Stick
The wifes truck
  #9
Old 07-29-2009, 01:18 PM
Try anything
Default
Thanks John. Ill have a look there today. Ive ordered a complete 7.1 from Guy that he says he will have to me around the end of August. Worst scenerio is we will have 2 engines. One for a race truck and one for my 04. but by the sound of this noise getting worse by the hour, I think we will have one engine for the 04 and one boat anchor
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #10
Old 07-29-2009, 03:47 PM
JOHNBOY's Avatar
Default
Mick
If you have open lash on exhuast valve it can and will make an evil noise. If it opens up enough the rocker bridge will fall off and it will sound even worse. Watch this video at the 2 min mark. The knock you hear is because the exhuast valves on cylinder number 1 was mot open hardly at all. It sounded horrible but was not as bad as it seemed.
__________________
The Big Stick
The wifes truck
  #11
Old 07-30-2009, 08:06 AM
05lly2500hd's Avatar
05lly2500hd 05lly2500hd is offline
(903)293-6026
Default
holy jeez that's a scary sound.
__________________
MAD AMERICAN DIESEL PERFORMANCE, LLC
Amsoil lubricants, S&B intakes, AFE, EFILive, MBRP, Suncoast, MPI twins, EFILive tunes and more...
website will be up soon...stay tuned..
(903)293-6026
  #12
Old 07-30-2009, 08:35 AM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
whats the oil pressure?
I hunted a knocking noise on 02bigstrokins motor for weeks, swapped injectors, tunes checked valves. It ended up being the heater lines going into the cab were rattling against the firewall.
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #13
Old 07-30-2009, 03:43 PM
Try anything
Default
Oil Pressure is good Travis
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #14
Old 07-30-2009, 04:11 PM
Try anything
Default
Mick
Pulled the Rocker cover off rh side and nearly all the clearances were way over 12 thou. 2 were up at 18 in fact one bridge looked like it could have fallen out with a bit more gap. Will put it back together today but I am sceptical that it is the cause (Id like to hope so) I did notice by moving one pushrod around and up and down there was a definate noise coming from the lifter that I couldnt get from of any of the others?
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #15
Old 07-30-2009, 09:02 PM
(903)293-6026
Default
Quote:
Could your pushrods be bent or warped?
That sound would make me pee my pants, I've had something similar twice, only both times it was major. Talking about a heartbreak.
__________________
(903)293-6026
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
