  #1
Old 07-20-2009, 03:30 PM
dracing70's Avatar
dracing70 dracing70 is offline
SH--- GETTING EXPENSIVE!
Default axle shafts
well i snapped a rear axle shaft this weekend (and still took second at the pulls) and i am lookin for axle shafts either aftermarket or stock i have not made my mind up. does anyone have any suggestions. i am not sure my exact setup yet whether it is 9.5 10.5 or 11 yet as the dealer said my truck could have either one. i have to run the numbers but i am lookin for some input.
__________________
Special thanks to Mark, Larry and everyone at Danville.
2004.5 lly 2500 chevy 4x4 very big Danville turbo, efi live, carrillo rods, so cal pistons ,arp studs ,brodix heads . Hsp manifolds and custom intake along with a DR Tuning custom stainless remote mount,very very very very very large exergy sticks,twin modded cp3 pumps. Tranny is obviously built with billet shafts in house by DR Tuning. Plus many other goodies!
also have a 2003 lb7 crew cab dually dark green mostly stock with stage five suncoast, full cognito front suspension semi 10 lug wheel kit with 19.5 alcoa's and s b intake
  #2
Old 07-20-2009, 03:37 PM
z79outlaw's Avatar
z79outlaw z79outlaw is offline
Default
If your going to pull alot there is are 39 spline shafts and a spool available. But Im guess thats not what your after. You definetely have a 11.5 ring gear AAM. I dont know why the dealer would be confused about that. Stock is probably the best option. You can get ones from Yukon and Moser I think too, but its debatable whether or not there strong that stock.
__________________
-Nick
Sold 08 GMC 4X4 CC/SB 6" Fabtech, BMF's
09.5 Last of the brand G8 GXP
98 Silverado 3500 Cummin On Strong- 12v cummins p-pumped nv4500
  #3
Old 07-20-2009, 03:40 PM
dracing70's Avatar
Default
really? you dont think stronger than stock. well i was leanin on stock due to the fact i would like to keep axles the week link since they are the least expensive even at near 500 each. yeah one dealer did not ask which axle i had and one did even with the vin. but i figured the larger even with a 2500
__________________
  #4
Old 07-20-2009, 03:42 PM
ecc_33's Avatar
ecc_33 ecc_33 is offline
Junior Member
Default
the rear is definately a 11.5 AAM axle. The only option that im aware of is Tony's full spool and big axle setup. There pricey but will hold about anything,.
__________________
02 extra cab long bed
Thanks: CRANK IT UP DIESEL PPE ATS SUPER DIESEL MCRAT RACING
CREATURES OF THE NIGHT BES RACING
Carrillo rods, Hamilton valve springs, ATI damper, 60% bigger nozzles, head studs, S475 turbo, 4inch lift kit, ATS dual fueler, ATS Tranny,Bunch of SD parts,lobonte water injection, AD 165gph,
best time 11.63 at 116 49,200 miles
  #5
Old 07-20-2009, 03:43 PM
ecc_33's Avatar
Junior Member
Default
I didn't know moser made axles for our truck? Doesn't SCS make axles too?
__________________
  #6
Old 07-20-2009, 03:56 PM
z79outlaw's Avatar
Default
Quote:
I think you can get stockers cheaper than that. Maybe see if you can get the wholesale price. But if they wont beat that. You can get stock replacment yukons for less that $300
__________________
-Nick
  #7
Old 07-20-2009, 04:02 PM
z79outlaw's Avatar
Default
Quote:
I thought moser did, I might be wrong though. SCS I dont believe makes axles for the AAM 11.5" not last I heard at least though. But the general concesus from the dodge D80 guys seems to be they wont hold, lots and lots of twisted shafts, even in 2.6. The rest of the stuff they make is bad ass though. The problem with there d80 shafts is there the same size as stock, just beefier material. Haisley's 37 splines seem the way to go for a D80 though. I was going to run a D80 with SCS's until I did a little research. So I picked up a AAM 11.5" up for $300 instead.
__________________
-Nick
  #8
Old 07-20-2009, 04:25 PM
JOHNBOY's Avatar
JOHNBOY JOHNBOY is offline
< Rocking the Big Single!
Default
Moser does make axles. They are not much if any stronger then stock IMHO. SCS did but last I talked to them the where out of stock. It has been awile though. I run the 39spline axles and spool from Tony Burkhardt. Very nice but not street truck stuff.
__________________
The Big Stick
2002 GMC 2500HD Crewcab Long Bed LB7 ZF6 Southbend Triple Disk clutch, Alive with EFI Live from Mcrat Racing, Crower rods, LB7 cut pistons by JB, Cam and push rods by EEP 80% Extrudehone injectors, CP3 X 2, Socal Diesel Springs and Ti Retainers, A/C delete by JB
The wifes truck
2007 Classic Chevy Crewcab Shortbed LBZ 6speed Allison Loaded Basicly stock. Little EFI tune and a Trans Go Jr.
  #9
Old 07-20-2009, 05:23 PM
dracing70's Avatar
Default
well just pulled it apart and definately an axle. the driver side and what started to seem like easy fix got alil more complicated after closer inspection the locker assembly has about 8 teeth broken off the locker assembly. the spiders are ok but the small teeth behind the inside spider are sheered as well as the little actuater teeth. so now what is that locker capable of being disassembled and does gm sell individual parts or is that a buy the whole assembly deal??
__________________
  #10
Old 07-20-2009, 05:39 PM
JoshH's Avatar
JoshH JoshH is offline
Default
Randy's Ring and Pinion lists a bunch of different axle shaft options on their website. Including a 38 spline option and matching spool.
http://www.ringpinion.com/PartsList....fID=32&CatID=1
http://www.ringpinion.com/PartsList....ID=32&CatID=12
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #11
Old 07-20-2009, 06:48 PM
JOHNBOY's Avatar
Default
I have a complete G80 here if you need it.
__________________
The Big Stick
The wifes truck
  #12
Old 07-20-2009, 07:02 PM
dracing70's Avatar
Default
g80? are you talkin about the chunk complete john?
__________________
  #13
Old 07-20-2009, 08:21 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
the G80 will replace your locker... Dodges used them... they're supposed to be stronger.
I have friends that run all four - Stock, moser, SCS and Tony's.
With the SCS, one is a 2.6 truck and one is a 2.8 truck. The 2.8 truck snapped one two weekends ago. The 2.6s look alright but they haven't had a chance to really hook on em yet. I think these are a fair bit stronger than stock and probably a happy medium between stock and the ones Tony has.
Another 2.8 truck is running Tony's and hasn't hurt them yet.
Another 2.6 friend has Mosers and he broke one (it's twisted) AND the diff. guts a couple pulls ago. I think they are only marginally stronger than stock but they are less than that price you just mentioned for stockers also. Won't be much good if they're out of stock though.
Good luck
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #14
Old 07-20-2009, 08:42 PM
JoshH's Avatar
Default
Quote:
The G80 is the stock locker that comes in our truck. Dodges use a helical gear operated torque sensing limited slip differential that works off the same principal as the Detroit TrueTrac.
__________________
  #15
Old 07-20-2009, 10:05 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Default
__________________
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
