  #1
Old 04-21-2009, 01:22 PM
Barlow Barlow is offline
Barlow
Default best mods for the money?
I have researched the duramax alot and i think im gonna buy the 2001 model i been lookin at. Its extended cad 4x4 with leveling kit and 20inch wheels on nitto mud grappler tires. What are the best mods without getting into the engine... and wont blow the motor in a month? And how high can you set the rev limiter without damage as well?
__________________
2001 ex cab 4x4 LB7
  #2
Old 04-21-2009, 01:36 PM
CancerPipe's Avatar
CancerPipe CancerPipe is offline
Default
If it doesnt already have them i would look into the cognito pitman/idler brace kit and tie rod sleeves . Depending on how it was leveled. I would start with an exhaust, intake, and some gauges. Transgo kit for the tranny, and a good tuner, maybe ppe standard. It all ready depends on how fast you wanna go. Maybe the Super Diesel intake horn, kennedy or ppe boost valve to help the turbo. That would be a great start.
__________________
04 LB7 CCSB 4x4
EFI Live OS:15189044
  #3
Old 04-21-2009, 01:52 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
as stated above decide what you want out of it first and we can tell you exactly what it will take to get there . wether it is a tow rig , fast daily driver, or all out race truck ... we can even tell how to get all 3
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #4
Old 04-21-2009, 04:41 PM
malibu795's Avatar
malibu795 malibu795 is offline
Default
Quote:
best mods for $$$
tranny
efi live
tie rod sleaves
lift pump
shocks
4,000rpm is easy
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #5
Old 04-21-2009, 04:52 PM
Barlow
Default
It will be more of a weekend truck. I will use it to pull tractor, boat, four wheelers, my trans am to track just to name a few so im lookin to boost towing and also make it a fast truck that will really surprise people when you lay the throttle down
__________________
2001 ex cab 4x4 LB7
  #6
Whitetail Addict's Avatar
Whitetail Addict Whitetail Addict is online now
Rockin' the stock tune
Default
Gauges first and foremost.
Then worry about more power
__________________
Brandon
'12 LML
'03 LB7
If you feel like everything is under control, you're not going fast enough - Mario Andretti
  #7
Old 04-21-2009, 04:54 PM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
exhaust, air intake, tuner, gauges, ppe boost valve.
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #8
03 D-max's Avatar
03 D-max 03 D-max is offline
Honorary "Tosser"
Default
Quote:
Originally Posted by malibu795 View Post
best mods for $$$
tranny
efi live
tie rod sleaves
lift pump
shocks
4,000rpm is easy
^what he said
__________________
JACOB
Post Whore want to be#1
Easter Whore Member#2
Team Borrowed Time Member#23
Quote:
Originally Posted by The Neens View Post
I don't spray much...Usually only after Mexican food
03 2500hd Efi Live, SD, PPE, FASS, MBRP, K&N
  #9
Old 04-21-2009, 05:01 PM
jonathancasey19's Avatar
jonathancasey19 jonathancasey19 is offline
yepppp
Default
tranny.....it will be your biggest limiting factor. go ahead and get it out of the way.
__________________
2002 LB7 ECSB Summit White
S366/74 .91 billet 6-blade race cover 360 thrust bearing, S&S 65% injectors w/BMS SAC nozzles, Exergy 10mm cp3, Cognito NTBD 4-6", EFI Live dsp5, Airdog 150, RDL's uppipes, SC IV w/1056, 6" stacks, Wherli Fab S366 intake, all custom led lighting & quad morimoto HID's, x2 12" subs, pillar gauges, debadged, Cognito brace kit & HD tie rods, Bilstein 5100's, 35x12.50 m/t atz's w/ 20" chrome rockstars
12.67 @ 105 w/ stock fuel system
  #10
Old 04-21-2009, 06:45 PM
SIKDMAX's Avatar
SIKDMAX SIKDMAX is offline
Highway Burnouts!
Default
Hey Barlow - for you there are a number of 'must haves':
PPE LB7 Boost Valve
Tie Rod Sleeves (prevents bending or snapping of the tie rods under off road use, or bigger tires, or racing, etc)
Pitman/Idler brace kit (again, a must with big tires to prevent slop in the wheel)
Lift Pump - delivers more fuel than the stock CP3 can suck
Programmer - Im sure you know
And as money allows, a built trans and maybe a turbo swap!
__________________
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM
Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057
  #11
Old 04-21-2009, 06:57 PM
motohed's Avatar
motohed motohed is offline
dirty payback
Default
one thing you might want to be aware of is with your leveling kit, your steering is almost at full droop, so even with upgraded steering you are going to get a lot of steering swap on boosted 4wd launches. i had to uncrank my torsions to the factory setting to launch in 4wd without the front end getting buck wild. you gotta do the cognito pitman idler support for sure and definately get sd sleeves or cognito hd tie-rods. even if you had stock suspension and tires
__________________
DIED 4/19/09 ALIVE 6/8/09
BIG THANKS TO CSC, SOCAL DIESEL, MIKE L. MCRAT RACING
MAHLE PISTONS, ARP STUDS, INSIGHT, BLOCKER PLATE, COGNITO HD TIERODS, PITMAN IDLER BRACE, 6"RCD, KMC MONSTERS, DE DOWNPIPE, PPE LIFT PUMP, MIKE L. ST. III, 1056, TRANSGO JR
ALL INSTALLED BY ME
  #12
Old 04-21-2009, 07:19 PM
n0useforaname's Avatar
n0useforaname n0useforaname is offline
knows your mom
Default
Don't know if this was mentioned, but another thing to look into is the Injector Warranty. I believe it's a 7 year 200,000 mile warranty. I'm pretty sure an 01 would be past, but make sure you aren't buying something that has bad injectors. It can be fixed, but if you don't have a good mech. or have to go to a dealer, you'll pay.
__________________
RIDE: 2007 Chevy CC LBZ / 6 speed
LIFT: 7 inch ZONE w/ Ready lift keys, Traction Bars, Nitro Shocks, and Compression Tubes
TRANS: Big Dipper Stage IV/PPE Deep Pan
SOUND:Touchscreen Pioneer P4000DVD/Backup Camera - 6 1/2 Polk Audio everywhere else.
ADD ONS: 40 overs, AD II 165, Oasis Diff, IronBull Bumper, Custom Rear Bumper, Cowl Hood, 5K/3K HIDs, Dominator II Steps, BFXenon Grill, ExTang Solid Fold, Custom Black Leather, US Speedo, Denali Trim, 13K Winch
TIRES/WHEELS: 35X12.50-17 Nitto Trail MTs on 17x9 Fuel Hostages, HD Sleeves
AIRFLOW: Blackout Performance Twins - FTE Single Stack - EGR removed
PROGRAMMERS: EFI live DSP5 - tuned by ATP
  #13
Old 04-21-2009, 07:24 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
Also whatch out for the head gaskets on an 01 truck
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #14
Old 04-21-2009, 08:11 PM
WanaDmaxsub's Avatar
WanaDmaxsub WanaDmaxsub is offline
Junior Member W/gray hair
Default
Gauges-EGT and Boost
Exhaust-4"
Front end stuff listed above
Tranny-'cause you'll hurt it before you hurt the motor. Also I don't think a Transgo kit would be enough. SunCoast level III with a new TC should last you along time.
Some thing to bump up the boost, but keep it under 32 PSI. Or it will cost you a turbo.
Forget the cold air intakes untill your over 500 RWHP.
Super diesels intake horn would be a good idea.
Lift pump
Now you can get a tuner EFILive (if you want to do your own tuning) or PPE (if you want a canned tune)
__________________
'04 C2500HD D/A LS EC SB, Chrome Nerf bars, Prodigy, Weatherflector, Breezer, A.R.E. Z w/accordion boot, Bedrug, H2's, Bilsteins, Predator, VR Straps, Bowtie Flag, Mag-Hytec's, SPA Boost/EGT, Corsa 4" SS Muffler, BigMouth Grille, SD Manifold(s), Allison built by MikeL, Airlift Superduty bags, Banks Bighead, Fugly '06 Mirrors, Van Aaken 230, Garvin Wilderness Rack, EFILive, Cognito Idler/pitman braces, Super Hitch, SD turbo intake, ML Tranny cooler
#1 04039B (Injectors) '01-'04 LB7's Special Coverage Adjustment
#2 #04-06-04-007H TSB (Injectors) '01-'04 LB7's
#3 07057 Engine Glow Plug '02-'04 LB7's w/YF5/NE1 Special Coverage Adjustment
  #15
Old 04-22-2009, 08:16 AM
radvans radvans is offline
Default
If you aren't going to get the trans done then just get efi live first....heck if you aren't going to do the trans then just purchase a cheaper used tuner that will give you about 100hp. You can tune efi to run "fairly" safe with the stock trans. It will make it feel relatively fast compared to a stock truck. If you do plan on doing the trans, then just purchase efi now...it will save you thousands in misspent funds...trust me.
The intake, exhaust, front end parts, turbo can all wait....because they aren't going to be a factor till you get the trans done. The programming will get you to as much power as the trans will hold. I had a stock exhaust/intake and dyno'd 466/8XX with them, and egts have rarely an issue even when towing. Heck with the tow tune I used last week you don't even need the gauges, I couldn't get the thing to go over 1200 no matter how hard I pushed it and I was towing 17,0000pds.
__________________
2002 2500 CCLB 4X4, 6" FABTECH, 315/75R16, 4.11, EFI, SCIV/1057 BY MIKE L
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
