  #1
Old 04-20-2009, 03:23 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Truck: 05 GMC EC/SB 2500HD
Engine: Duramax LLY
Transmission: Automatic
Default Duramax Valve Lash Tutorial.
First a little background information -
A four-stroke engine, like our Duramax, has intake valve(s) and exhaust valve(s). In our case, we have 2 intake valves and 2 exhaust valves for each cylinder. These valves are open roughly 200 degrees of crankshaft revolution. Since a four-stroke engine requires 2 full crankshaft revolutions to complete a power cycle (360° x 2 = 720°), the valves are open less than one-third of the time. When the valve is open, the lifter is riding on the camshaft lob and the pushrod and rocker arm is holding the valve open. But when setting the valve lash or clearance, we are concerned about what the valve is doing when it's closed, and the cam is on it's base circle with no lift. With solid lifter engines, you must have some "play" in the lifter/pushrod/rocker-arm assembly or the valve won't shut completely, and you will have low compression, poor performance, and you'll burn the valves. If you have too much "play", you will have poor performance, excessive noise and perhaps shorten the life of the valvetrain components. We call this play "lash" or "clearance". For our engine, the recommended number is 0.012", aka twelve thousandths. This allows for heat expansion and valve face/seat wear. Most engines will get tighter (less lash) over time in my experience. You can make a little more high RPM power by running towards the tight side.
Your Duramax engine is 32 valve V8 with 16 pushrods that rides on a solid lifter roller cam. Normally the valves will never require adjustment during it's service life. But for us hotrodders, you will need to do this if you:
Swap heads
Swap pushrods
Swap headgaskets
or anything else that might change the valve adjustment.
You should not have to do this if you just change to head studs, but you might as well check them when you are there.
I imagine GM has a great procedure for these, but I haven't bought the service manual. So this is the way I adjust valves on bikes, cars, trucks, boats, lawnmowers, or anything else I've tampered with.
You will need:
36mm 12-pt socket and breaker bar/ratchet
14mm wrench (I like using a long handle version)
A set of feeler gauges that includes a single 0.012" blade, or whatever value you are setting them to.
OK, I do engines at TDC (Top Dead Center) compression-stroke only. There are 2 TDC's for each cylinder, TDC Compression, and TDC Overlap. Both valves are closed on Compression, and both are open slightly on Overlap.
I'm going to do them by the firing order as well, to insure I do not skip a cylinder. My way takes a couple minutes longer, but IMO is less troublesome.
Our firing order is 12784563:
  #2
Old 04-20-2009, 03:25 PM
McRat's Avatar
Diesel Hotrodder
Engine: Duramax LLY
Default
I'm going to start with Cylinder #1, which is the passenger side front. So I'm going to line up the timing marks on the harmonic balancer:
  #3
Old 04-20-2009, 03:28 PM
McRat's Avatar
Diesel Hotrodder
Engine: Duramax LLY
Default
What if you don't have the harmonic balancer on, or it's not marked?
You can find TDC by just looking down the injector bores, this method is plenty accurate for setting valves, you don't have to be EXACTLY TDC:
  #4
Old 04-20-2009, 03:46 PM
McRat's Avatar
Diesel Hotrodder
Engine: Duramax LLY
Default
Something to note, when #1 is at TDC, so is #4, and likewise:
1-4
2-5
7-6
8-3
are matched up as well. When one cylinder is at TDC Compression, it's brother on the opposite side is on TDC overlap. We can tell which is which by grabbing the rocker arms on those two cylinders and squeezing (see pic):
We want the cylinder that has play in it. If #1 is on Overlap, we could adjust #4, which would be on compression, but instead, I just rotate the crankshaft a complete revolution, so #1 is now TDC Compression so I can adjust it.
  #5
Old 04-20-2009, 04:12 PM
McRat's Avatar
Diesel Hotrodder
Engine: Duramax LLY
Default
Now to adjust both the valves on #1 Cylinder. Take your 14mm wrench and loosen both locknuts (see pic above post) and rotate them about a full revolution loose. Turn the adjustment screw out one full revolution, then slide the 0.012" feeler gauge in the gap between the rocker arm and bridge.
Tighten the adjustment screw as tight as you can with your finger tips, then tighten the 14mm lock nut with your wrench. Check the feeler gauge now. It should have a light drag when you slide it. If you can get a .014" gauge in, try again. If you can't force the .012" in after removing it, then try again. The finger tight thing works good for me.
  #6
Old 04-20-2009, 04:18 PM
McRat's Avatar
Diesel Hotrodder
Engine: Duramax LLY
Default
Now we do the next one in the firing order, which is #2. We rotate the crank 90° clockwise, look to see the piston, then adjust. Rotate 90° more, and do #7, rotate 90° more, do #8, ... until you finish off at #3 at 270° second rev.
Check each locknut again for tightness, and you are done.
Yes, I rotate more than is absolutely necessary, and there is certainly other ways. Get #1 at TDC Comp, and you can do 1-2, rotate 180° and do 7-8, rotate 180° do 4-5, rotate 180° do 6-3.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #7
Old 04-20-2009, 05:18 PM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
Wow Pat, this is an awesome tutorial thank you very much.
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #8
Old 04-20-2009, 05:46 PM
emiller3's Avatar
emiller3 emiller3 is offline
He's Back
Truck: 07 classic,cc,sb,4wd
Engine: lbz
Default
Awsome write up.Just finished having mine done friday once the motor was back in the truck.I should have done it myself while it was on the stand but I was tring to hurry and it ended up taking even longer.
__________________
Everett. KCCO
07 lbz,ccsb,4wd
EED,TTS ,Danville,PPE,RDL,
Calvins,BT,F1,& Driveway
11.08@127.86mph
02 lb7,sclb,4wd
Waiting on a transplant
  #9
Old 04-20-2009, 09:05 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Truck: 2001 duramax
Engine: 6.6 duramax lb7
Default
Excellent write up pat .
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #10
Old 04-20-2009, 09:55 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is online now
Book 'em, Danno!
Truck: '01 Ext. Cab LB 4x4
Engine: LB7
Default
nice write up.
i checked in my factory service manual for the lb7 motor and it said when cylinder 1 is at top dead center on the compression stroke you can adjust the valves:
Cylinder 1 intake and exhaust
Cylinder 2 Exhaust
Cylinder 3 intake
Cylinder 5 Intake
Cylinder 6 Intake
Cylinder 7 Exhaust
Cylinder 8 Exhaust.
and then you can rotate the engine one revolution to bring the number one cylinder to the exhaust stroke and then you can adjust these valves:
Cylinder 2 Intake
Cylinder 3 Exhaust
Cylinder 4 Intake and Exhaust
Cylinder 5 Exhaust
Cylinder 6 Exhaust
Cylinder 7 Intake
Cylinder 8 intake.
And the valve clearance lock nut is torqued down to 15lb ft or 21nm.
the intak valve has the smaller rocker and the exhaust has the longer rocker. you can get a good look at it on post 3
__________________
theres a new sheriff in town
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #11
Old 04-21-2009, 12:06 AM
durallymax's Avatar
durallymax durallymax is offline
Default
^^^thats how i did mine.
The mark on the block to line up with the mark on the balancer, is on the lower passenger side. Lets say your looking at the balancer from the front, the line up point will be at about 7 o clock
__________________
"The Maxitron"
2018 LYZML DMaximus/Allitron
Bully Dog Shift Kit, Stock Clutches, TTS C3, other "secret" mods, Amsoil Plutonium fluid,BHAF,#10 Fuel Plate,Cracked,Honed,ceramic plated 956% Injectors, OCTA-CP3.9 Pumps(that would be 8), Billet Everything, Aluminum Rods, Titanium Aluminum Sodium Bi-Carbonate Space Alloy Block, HX9000 Bi-Compounded Triple Quad Turbo's, Turbo Silencer Rings Removed, Water Cooled Canuter Valve, Cryo Treated Rotary Girder
36" Stacks
Homomod by Brian
Lockup Knobber by Ben
Tuned by KE$HA while on a boat.
3.967 @ 452mph
4,324,756hp
  #12
Old 04-21-2009, 12:34 AM
othrgrl's Avatar
othrgrl othrgrl is offline
Diesel Addiction Owner
Truck: 05 EC SB LT
Engine: 6.6L LLY Duramax
Default
Great write up.
OT but I do hydraulic lifter motors the same way only with preload instead of lash. If you know the thread per inch on your rocker arm studs you can calculate preload in relation to how many degrees of rotation you turn the nut. For example lets say your studs have 20 thread per inch, it would mean you need 20 turns to go down 1 inch; and we'll say your desired preload is .030. 20 x 360* = 7200*. 7200* x .030 = 216* or .6 of a turn.
2500HD - the only thing that would keep from from doing that method would be if you had some kind of aftermarket cam.
__________________
Dustin
05 Chevy ECSB SS, DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only
835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09
DIESEL POWER CHALLENGE 2010 - 3rd Place
Coasted to a 10.74 before retirement to street truck status.
  #13
Old 04-21-2009, 04:01 AM
TIM Z's Avatar
TIM Z TIM Z is offline
Screwed by 0087s
Truck: 2007 duramax ccsb 4x
Engine: LBZ
Default
Pat, thankyou for explaining this. Its very clear and understandable for someone like myself who has never done this before.
__________________
2007 CCSB 4x4 Duramax LT3 LBZ
M A STG III Allison- S.C. T-Case brace/Pump rub Fix
Precision Industries M L Race Converter
EFI LIVE V2 DSP5 ACID Tune by DIESEL ADDICTION
Twin Lift Pumps/ Race Valve
6'' T.C. Strong kit/Cognito Braces/SD sleeves.
some other goodies.
2000 ECSB Z71 -6.0 LQ4 BLOWN -TVS 1900 10 psi - Comp 226*-224*/ Dyno Tuned By TJ @ Baker Engineering/SS LT Headers/ RPM LVL VI 4L70E Billet output/ Precision 2600 Vigilante Stall. Hauls Ass
  #14
Old 04-21-2009, 06:21 AM
EatSoot's Avatar
EatSoot EatSoot is offline
diesel idiot
Truck: 2004.5 CCSB 4X4
Engine: LLY
Default
excellent information.
__________________
2004.5 2500HD LLY/Allison Crew Cab 4WD Black on Black - Leveled with Bilsten Shocks - EGR Blocker Plate and resonator delete - Roll and Lock Bed with a 60 Gal. custom auxilary tank - Cognito Idler and Pitman Steering Braces - Jotto Laptop Mount - MBRP SS 4" Turbo back exhaust - SD Stainless Steel Tie Rod Sleeves - All on Headlight Mod - Quick release Oil drain valve - EFI Live V2 with DSP5 from SoCalDiesel - PCV Reroute - 3 Gauge A-Pillar with Pyro, Boost and Aux Fuel - LBZ Air Intake MP - 10 and 2 micron in line fuel filters - KD Lift Pump - KD Pump Rub Fix
  #15
Old 04-21-2009, 07:30 AM
Book 'em, Danno!
Engine: LB7
Default
Quote:
Originally Posted by othrgrl View Post
Great write up.
nice to know
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
