  #1
Old 03-25-2009, 12:43 PM
02bigstrokin's Avatar
02bigstrokin 02bigstrokin is offline
Default bent rod!
well i took my piece to gm today because i thought i had a fuel knock and my injectors were bad so i took the twins off and got up there and nope, not injectors, return rates are fine, balance rates even better, but when you ramp up the rpm's and cut out cylinder 7 the noise pretty much stops. tech said it sounds mechanical to him. he seems to think cracked piston, but i think maybe the rods bent and maybe the wristpin is hitting. the crap sucks as i never even got to get on it from a standstill with the twins.
__________________
Iím Kenny Powers! And I am very upset with how I am acting right now. I just have a very hard time expressing my emotions, and I canít stop from yelling.
  #2
Old 03-25-2009, 12:46 PM
Default
oh and to add to it, the BADASS lbz modded cp3 pump i just put in, wont do anymore then 23,200 psi.
__________________
  #3
Old 03-25-2009, 12:52 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
crap
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #4
Old 03-25-2009, 12:54 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
Quote:
just a thought but if it was a bent rod why would the noise stop when you cut fuel to #7 cylinder , the crank and rods are still spinning ? could very well be mechanical but compression check should be a first step in deciding if the rods bent , and maybe balance rates but you said they were fine . and 23,200 psi what is the pulse width of your tune ? that pretty decent for a lbz cp3 depending on how modded it is, with my stock lb7 cp3 i could not go past 3250 usec without going under 21k
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #5
MMLMM's Avatar
MMLMM MMLMM is offline
Default
it really should should it?
It should just hold that pressure, stock one would just fall off....
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
  #6
Old 03-25-2009, 12:56 PM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
sorry to hear about this
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #7
Old 03-25-2009, 01:02 PM
Bako_Dmax's Avatar
Bako_Dmax Bako_Dmax is offline
GTO Slayer
Default
Do compression test.
__________________
2006 Chevy LBZ
MBRP exhaust, Shimmed FPRV, Blocked EGR
Homemade Lift Pump W/ Bypass
Homemade Pitman & Idler Braces
Tierod Sleeves
EFI Live
Built trans w/ triple disc
Homemade Twins S475 w/ 38mm gate
  #8
Old 03-25-2009, 01:27 PM
Burn Down's Avatar
Burn Down Burn Down is online now
Default
That sucks, but look at the bright side, with a set of rods you can take full advatange of your twins.
  #9
Old 03-25-2009, 01:41 PM
othrgrl's Avatar
othrgrl othrgrl is offline
Diesel Addiction Owner
Default
If it's a cracked piston you'll have excessive crankcase pressure. Fuel or not you would likely (but not necessarily) have the noise if it was mechanical.
Looking at a log from a full pull that Chris got with his LBZ it held about 22,000psi of rail pressure with a bone stock CP3 and no lift pump. With a lift pump it holds over 23,000 down the track during 12.4 passes but has areas over 25000psi.
The max pressure a stock LB7 tune demands is 160MPa which is 23,206psi - sounds like it might be a tuning issue. Even with dual CP3s you won't get more pressure unless you ask for it and allow it.
__________________
Dustin
05 Chevy ECSB SS, DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only
835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09
DIESEL POWER CHALLENGE 2010 - 3rd Place
Coasted to a 10.74 before retirement to street truck status.
05 Chevy RCSB - Shop Race truck in very slow progress.
04.5 Chevy CCSB "Old Man's 1500HD" Clone - Shop Work truck thrown together with spare and scrap parts. 11.81 @ 115------7.54 @ 92
  #10
Old 03-25-2009, 01:45 PM
dmaxvaz's Avatar
dmaxvaz dmaxvaz is offline
wannabe puller
Default
well i took my piece to gm today because i thought i had a fuel knock and my injectors were bad so i took the twins off and got up there and nope, not injectors, return rates are fine, balance rates even better, but when you ramp up the rpm's and cut out cylinder 7 the noise pretty much stops. Tech said it sounds mechanical to him. He seems to think cracked piston, but i think maybe the rods bent and maybe the wristpin is hitting. The crap sucks as i never even got to get on it from a standstill with the twins.
X2, if you have a bent rod, the piston skirt would be hitting the crank all the time, not when you cut a cylinder out will the noise go away. More than likely the injector is at fault. Is it blowing oil out the vent? Do you have smoke out the exhaust? I thought i had a bent rod and i did a compression test, and found i have 400-410 psi on all cylinders. your issue is after the lbz pump swap and the tuning it to idle right.
__________________
01 chevy 2500hd rclb, all work and no play! boss v plow, 65 hp predator tune, afe intake, dimondeye 4" exh., 285s, stock everything.
02 chevy 2500hd ccsb, rancho 9000s. suncoast IV w/1057, EFI LIVE dsp5, AD150. LBZ CP3. Kriptonite centerlink/tierods. 305/55r20s Toyo a/t. Billet wheel s366/74 by Northwest Diesel Service and Performance. BD Blowoff valve. New best 1/4 mile time: 12.59 @106.62. Toman Tuning Inside.
  #11
Old 03-25-2009, 02:17 PM
TrentNell's Avatar
Default
keep us posted with what you find , but i would do a few other test before you let the dealer tear your motor down .
__________________
Trent Nell
  #12
Old 03-25-2009, 02:38 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
Quote:
The dealer wont be touching this one. I am on the hunt for a compression tester right now
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #13
Old 03-25-2009, 02:39 PM
Default
when we checked this today the tech had the truck in gear with the parking brake on and would cut out number 7 and it stopped. he said it quits because with out the fuel in there, theres not any pressures on that cylinder, and thats why it quits. i dont know much about them, but i do know we checked eveything we could about the injectors and he said they were some of the closest tolerances hes seen. note: this tech is my foremans good friend not just some dumbass thats just trying to get me out of his hair. hell he was going to do the injectors under warranty knowing that it had twins on it and all. as far as the pump goes, im mistaken because i took it to him with a stock lb7 tune in it with just b1010 changed to make it run smooth, so 23,200 is right. and for smoke, its been smoking white when first started, and really this happened the first time i got down on it with the twins. i was going to my friends house and rolled on it hard in 3rd and afterwards it sounded like i had an exhaust leak. well its not an exhaust leak and its steady getting worse.thanks for all the advice. i will do a compression test when i get my hands on a tester.
__________________
  #14
Old 03-25-2009, 02:40 PM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
I had a noise in mine too not too long ago. The tech found it by turning the injectors off one at a time, turned out # 6 injector was leaking past the seal, replaced that one injector and the noise went away. If your not experiencing the other symptoms of a cracked piston/bent rod I'd have them look at the injector they turned off when the noise quit. The noise I had sounded like a ticking or exhaust leak under acceleration, got worse of the course of several months.
On edit, mine started with the addition of the larger turbo.....................check your injector seal
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #15
Old 03-25-2009, 02:43 PM
Default
thats exactly like mine. cant really hear it bad in park, put it in drive and its real noticable with a load on it. sounds like a ticking noise and is steady getting worse.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
