  #1
Old 03-20-2009, 12:40 PM
lotsofmiles lotsofmiles is offline
Father of the Van
Default HELP! oil pressure low! gauge dropped to nothing!
cruising on the eway my oil pressure gauge dropped to nothing. I stopped the truck. everything looks and sound normal and I have enough oil in it. what should I check next. feel free to call, i'm sitting in a parkinglot trying to figure this out. thanks all
Posted via Mobile Device
__________________
Quote:
Originally Posted by Jeremy Clarkson View Post
Some say he was conceived in a cargo van
  #2
Old 03-20-2009, 12:43 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
Noc check engine lights? I beilive if the oil pressure drops below 40psi the CEL will come on.
This is in your 07 right?
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #3
Old 03-20-2009, 12:46 PM
Father of the Van
Default
Yes in the LBZ, no codes, no cel. just the display on the dash said oil pressure low.
The gauge dropped to nothing.
Engine sounds normal, and there is plenty in it, no signs of a leak or blow out that I can see yet. I ran it about a mile or 2 to get off the eway into a prk lot.
About 3000 miles since last oil change.
Been cruising the eway all day no problems till now
__________________
  #4
Old 03-20-2009, 12:47 PM
Father of the Van
Default
Bad sensor? where is it?
just a thought
__________________
  #5
Big Girl!
Default
You dont have EFI live or anything do you?
__________________
Travis
03 CCSB lb7
special thanks:
  #6
Old 03-20-2009, 12:48 PM
Big Girl!
Default
Quote:
just a thought
Sensor is on the drivers side of the block under the exhaust manifold towards the back of the block. Should be a 3 wire plug
__________________
Travis
03 CCSB lb7
special thanks:
  #7
Old 03-20-2009, 12:51 PM
Father of the Van
Default
I got efi with me, but dont know how to use it...
banks 6gun says no obdii codes
__________________
  #8
Old 03-20-2009, 12:53 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
Pat says check the bale connectors. He said it happened to Blue once.
When we lost the oil pump in Casper it would clatter when he started it.
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #9
Old 03-20-2009, 12:54 PM
Father of the Van
Default
Quote:
I see the 2 wire sensor plugged into oil pan, followed that up to a 3wire sensor. is that it?
it's still plugged in wires are fine.
__________________
  #10
Big Girl!
Default
But you have a laptop and all the EFI software installed right? If so I can walk you through how to read oil pressure to determine if its a bad sensor or the oil pump took a dump or you cluster messed up
__________________
Travis
03 CCSB lb7
special thanks:
  #11
Old 03-20-2009, 12:55 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
no it wont set a code, it will just give a warning in the DIC and start dinging at you.
Most likely a oil press sensor issue. The oil press sensor is kinda tricky to get to, its up behind the oil cooler sort of. As a quick and dirty check, you can crack open the oil line feeding the turbo, fire up the truck, and see if oil comes out. If oil comes out then you have pressure and its just a bad sending unit.
ben
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #12
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
did you actually check oil? Thats how I knew I needed injectors finnally, because crankcase was filled with fuel.
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #13
Old 03-20-2009, 12:56 PM
<--- slippery roads
Default
how is efilive going to tell you if the sensor is bad...?
the ECM and the instrument cluster [and efilive] all get their readings from the same sensor...
ben
__________________
  #14
Father of the Van
Default
Bale connectors? feel free to explain
__________________
  #15
Old 03-20-2009, 12:57 PM
Big Girl!
Default
ben
it wont I was typing in a hurry
__________________
Travis
03 CCSB lb7
special thanks:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
