  #1
Old 02-03-2009, 08:49 AM
REDHOSS02's Avatar
REDHOSS02 REDHOSS02 is offline
hard n heavy
Default Block heater
How hard is it to replace the block heater on an lb7? Instructions please!
__________________
2007 silverado LBZ
Efi live dsp5 Idaho rob
EGR BLOCK
35x12.50 black H2's
MOTFW bumpers
OLD LB7- prob in mexico!
  #2
Old 02-03-2009, 08:52 AM
malibu795's Avatar
malibu795 malibu795 is offline
Default
it was some what difficult with the block out...
it is located front rigth corner (pass side front) int he first freeze plug hole.
right in fornt of the engine mount
ill post a pic of it as i have on the is out of my old engine.
coolant will have to be drained.
best way to it is through the pass wheel well with tire removed, CAC pipe as well.
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #3
Old 02-03-2009, 09:04 AM
REDHOSS02's Avatar
hard n heavy
Default
Thanks for the input! I am haveing the engine rebuilt right now and i dont know if he is going to replace that under the cost or not. So if not i am going to have him go ahead and do it now while the engine is out. I just figured if it was easy then i would wait and do it myself!
__________________
2007 silverado LBZ
EGR BLOCK
35x12.50 black H2's
MOTFW bumpers
  #4
Old 02-09-2009, 07:11 AM
REDHOSS02's Avatar
hard n heavy
Default
No one has these in stock in texas. What the hell! Haha shoulda known
__________________
2007 silverado LBZ
EGR BLOCK
35x12.50 black H2's
MOTFW bumpers
  #5
Old 02-09-2009, 08:34 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Try here....I got mine at a local parts store made by Zero Start
http://www.zerostart.com/coldStart/e...ck_heaters.asp
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
