  #1
Old 05-29-2007, 02:26 PM
mick mick is offline
Try anything
Default Crankshaft Pulley Keyed?
Could somebody tell me if LLY Crank Pulley is keyed or just a Press fit like alot of engines seem to do these days. Appreciate info and hope somebody gives me good news and says it has keyway - Mick
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #2
Old 05-29-2007, 02:48 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
mick i am 99.9% sure it is keyed, if not the crank pully could rotate on the shaft, i even think there have been problems of people not getting their pully tight enough and sheering the pin off
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #3
Old 05-29-2007, 02:57 PM
Try anything
Default
double posted
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #4
Old 05-29-2007, 02:59 PM
Try anything
Default
BFJ Thanks.I'm hoping so - if not bit of machine work to fix it so I can run S/C pulley. My manual shows pic of it but doesn't show keyway. There are a few around now that will know for sure and will chime in -
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
  #5
Old 05-29-2007, 04:13 PM
JOHNBOY's Avatar
JOHNBOY JOHNBOY is offline
< Rocking the Big Single!
Default
There just a pin in the snot to drive it. The pulley just slips on. The BMF bolt holds it all on.
__________________
The Big Stick
2002 GMC 2500HD Crewcab Long Bed LB7 ZF6 Southbend Triple Disk clutch, Alive with EFI Live from Mcrat Racing, Crower rods, LB7 cut pistons by JB, Cam and push rods by EEP 80% Extrudehone injectors, CP3 X 2, Socal Diesel Springs and Ti Retainers, A/C delete by JB
The wifes truck
2007 Classic Chevy Crewcab Shortbed LBZ 6speed Allison Loaded Basicly stock. Little EFI tune and a Trans Go Jr.
  #6
Old 07-10-2007, 08:53 AM
LBZ's Avatar
LBZ LBZ is offline
Default
Well that's gay!! No wonder they shear occasionally. Anyone know what the torque is on that BMF bolt!! Is it Right hand or Left hand thread?
  #7
Old 07-13-2007, 03:15 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Bolt is standard right hand thread. Get the biggest cheater bar you can, then go get another a bigger one. Then use them both. My 3/4" impact won't phase it.
I think the official torque spec is one bazillion ftlb's, but I think they are tighter than that.
Do not reuse crank bolts. Ever. These are always to be replaced on modern GM engines when removed.
And yes, the LB7/LLY/LBZ crank is pin'd with a Walmart Quality extra-dainty pin. Cheap bastards.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #8
Old 07-13-2007, 02:04 PM
Try anything
Default
Thanks for that. I'll be taking mine off LB7 engine next week
__________________
2004 CHEV 2500 CC
2003 GMC 1500 EC
2011 CHEV 3500 CC
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LMM Belt noise vzfarms Smoke Signals 8 01-11-2011 02:53 PM
vB.Sponsors
