  #61
Old 03-30-2018, 07:30 AM
Chevy1925's Avatar
factory gears always setup the best imho but ive never had much issue with Yukons. i just setup a set of used yukon 5.13 gears for my ford 8.8 going from stock 3.73. only needed .004 more pinion depth and off set the ring gear to the driver side .0012 from factory shims. pattern is dead nuts center and great depth into the tooth. to get a used gear to setup like that is hard to come by.
James
best time to date: 12.39
Tailgate Crew Member #4
  #62
Old 03-30-2018, 09:05 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Originally Posted by jpowel29 View Post
Any noticeable differences between the Yukon gears vs going back with the AAM gears - as far as quality/durability and gear set-up?
I've run the Yukon 4.56 and 3.73 gears in other set-ups. Was thinking about getting AAM if I decide to do this swap.
AAM are stronger. Sled pullers have proven this but unfortunately aam has discontinued the ratios most commonly used in pulling. I think they still make 3.42 3.73 & 4.10
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #63
Old 03-30-2018, 09:11 AM
Chevy1925's Avatar
i dont think strength will be the issue in a 3.42. pinion is getting larger and still plenty of meat on the ring gear. under 3.0 might be an issue. i could definitely see where the AAM are stronger in a sled pull in the 4.56 gear ratios.
James
